what 'basic' network tester?
11 Oct 2005
Derbyshire
What is a good basic network tester for testing RJ11, RJ45, cat cable etc.
Is this one any good for basic use.
Dont wish to spend a fortune but thought as I am about to do some routing of home network cable it maybe useful to have a basic one and I am sure it will come in useful in the future.
Noticed on Ebay there are loads. Can I have some info on what you would advise for just home use.
thank you
thanks
Anything cheap will just test continuity - it checks that the cable is connected correctly and that a few volts will run down it to light up the LEDs.
Far better Fluke ones will certify the wiring for 100Mhz / 250Mhz - it checks for crosstalk and will certify the cabling for data use rather than just being 8 pairs of bell wire. These ones cost a blinding amount of money.
I'd therefore say "Anything cheap from ebay, don't take the mick with the bend radius on your cable and you'll be a-ok". When terminating the cable, don't untwist more than the utter minimum (2-3mm)
Cheap one is fine. As said above if the cable isn't hairpinned all over the place you're unlikely to get any weird stuff. It'll be a case of a pin is terminated or it's not, any cheap tester should reveal such faults.
It's rare that cables get damaged in the middle of a run, usually they're either crap terminations or [paris get completely severed.
Better off buying a multimeter to be honest with continuity buzz. Least it has some other uses after the install.
I have one of those digital ones. No idea what it does. Never looked into it. Has a dial and LCD on it. Loads of things but id be damned if I know what any of them do apart from continuity bit.
