- 28 Dec 2009
- Wales
Right so I ordered a 920 for my shiney new i5 running at 4.6. I ahve two Akasa Viper fans in the case as front intakes, though the CM silencio has very little air flow.
Can I/Should I put the two vipers on the 920? And revert to the stock cas efans for intakes or use the antec supplied fans for intakes?
Will the vipers work fine on a 920. I knwo they have a lower max rpm than the ones antec supply. My only concern ebing that the 920 has software with it and if I change the fans the software might be expecting hgiher rpm?
