- 23 Dec 2009
- RG8 9
How can I go back to 5?
I need my dark theme back.
Stylish works perfectly fine....I'm using it.
Do as I posted earlier and you will be fine and all extensions will work just fine.
Surely you know how to use Stylish since you had the dark theme?
go to about:config
Add a new boolean entry for extensions.checkCompatibility.6.0 and set it to False. Now all extensions will install and run just fine.
I don't even know what you typed means.
Would you be kind enough to tell a noob?
go to about:config
on the beta channel so now my default firefox version is 7.0!!
Is it really essential to have such software installed and toolbarring up your browser in this modern age? You're using Firefox so do it a favour and install AdBlock Plus and NoScript for the ultimate browser security solution.
