Are you going to use 480 and a 240 rad and the D5 pump at the bottom? Do you have enough space to put angled compression fittings(45 or 90?) after fixing the fans?
I'm using a thick 480 and a thin 240 and the 480 will have push/pull and possibly the 240 and i'll use angled compressions for those. The pump will sit at the bottom of the drive bays.
I'll see if the pump fits at the bottom with both rads though
