****Official Nvidia Refurb Thread****
The 480s can run hot,but will be fine in decent case with good airflow.
Its only until you overclock the 480 and add more voltage where the temps get silly,thats from my experience anyway.
I run a 480 inside a SFF Sugo case. It idles at 45 (summer temps) and never goes above 70 running a custom BIOS with very low noise fan profile. 480's can be made to run very cool and quiet if you are prepared to do a little research.
I run default 3D clocks at 30% fan with reduced voltage @ 0.9v (down from 1.05v). I also edited my 2d clocks to run at lower core speed with 0.7v. My Sugo SG08 with an i5 2500k, P8H61-I mobo, 8gb ram, dvd, 3 hdds and a GTX480 idles in Win7 desktop at just 75W. CPU and ram are also undervolted and all are running stock clocks.
The 480 is a great card that will equal or beat any single GPU that AMD currently produce, and it will equal 580 performance if you overclock.
For that price, I bought two :cool:.
EH! no need to be greedy, save some for the rest of us.:p Fair play mate, that'll be a very fast setup. I hope you've got a nice roomy case with lots of air flow and a good PSU. Will you be watercooling them or sticking with the standard air coolers?
Lol
This is hilarious
Gibbo are you getting into a price match war with your competitor?:eek:
Its like watching a gaming of tennis between the two companies !:D
Yeah, it is like tennis.
Gibbo is currently 2 sets to 1 up and currently in a tie breaker in the third set!:eek: C'mon Gibbo! get those oc'uk power shots from the baseline going, and get some further reductions on those 480's & 580's mate!
To be honest, I think I'll be selling the second one whether it be online or to a friend who might want to upgrade from his 4870x2. I was thinking using both but I only have a HX650. I used a PSU calc and while the PSU was above the minimum, it was below the recommended so I'm not going risk it. Besides, I don't trust those PSU calc all too much anyway! 2 480s for around the price of a single 580 is just mind blowing, it's kind of similar to when the 5850s were only 100 pound on here when two of those blow a single 6950 out of the water that costs the same price as two 5850s!
I just can't make up my mind whether going to a 480 from a 5850 is worth it...
Ignoring power consumption, I just can't get an idea on how much more performant overall it is. Most of what I look at makes me think ~50%
But a few things have seen make me think closer to ~25%.
And then theres new cards out from AMD this year, and in just a couple of months something ~£200 could likely be far more powerful.
pretty much my thoughts with having a GTX 460
I went from a heavily clocked (1000/1250) 5850 to my 480 and it was a good move. I got so fed up with stuttering in Call of Pripyat with the 5850 as it was extremely annoying. Swapped to the 480 and no stuttering, higher framerates, especially minimum and average. The drivers just work as well with the 480. No messing around like some of the ATI drivers.
http://www.anandtech.com/bench/Prod...7.118.119.120.121.122.123.124.125.126.127.128
You could sell your 5850 for 90-100 and spend 49.99 on an upgrade. Plus the resale value when you move to next gen.
Its a no Brainer imo.
