As it says on the site, "Due in soon, taking pre-orders."Is it in stock though?
Just a word about the camera.
It's actually better than I was expecting. Yes, it can't handle macro shots but it holds enough detail so you can still make out text on paperwork for example even if you have to take the picture from further away.
While the EDoF lens isn't ideal, it has one good advantage; if something is moving, you don't get any blur. Many, many phone cameras suffer from blur problems because there is movement. It isn't great in low light, but no phone cameras are (even the mighty N8!).
It isn't particularly brilliant but it is perfectly acceptable. Outdoors you can take a decent picture. They look especially great on the crisp phone screen too.
I know this isn't a phone you would buy for the camera but it's handy to have one on you at all times.![]()
Who ever has the phone can you check if there is any memory card in the box or the phone ?
It does, guess they've upped the memory sufficiently on the 9900 not to need one though?I swear my old 9780 had a memory card !!
Indeed, it's got the iPhone 4-esque feel to it, very premium.
I suppose the only Android handset with that sort of feel (though not to the same extent) is the HTC Sensation but it's quite poorly put together once you actually look past the aesthetics.
Is it shameful that I don't have anyone on BBM? Are there like discussion groups on it or something I read somewhere? I really don't know much about it other than that it's popular with young girls and for organising riots![]()
