Could just get a car that doesn't understeer like lul if you boot it?
Mazda 6/ST220 or new shape Titanium X
You've just said the Vectra isn't going to win any awards for handling. The Mondeo has fantastic handling, far above the Vectra. So why does that then make the Vectra better?
The Ford V6 is just sublime and the power is enough for the car. The build quality in the Vectra is pretty 'lol' the same can't be said for the Mondeo. The Mondeo can be had for less, and it will be more reliable with less to go wrong.
For some there's more to a car than a remap and going 'POWER!' on the motorway slip road, and if that's your taste then why not get a Scooby?
They are not as quick.
I've gone from an Insignia VXR to basically a Vectra VXR (it technically isn't, it's ex-police so VXR engine, map, brakes etc but SRI interior).
The Vectra is a decent car but won't win any awards for handling. In a straight line it is very capable and after a small remap will happily pull with over 300 BHP with max BHP & torque at approx 2500 revs. It is better then the astra imo but obviously a 330i will be better. Dont let anyone make you believe a ST220 is better though because it's not.![]()
The 2.8 V6 in the VXR is a better engine and more reliable.
The interior is better in the ST220.
Ok. Thanks for the opinions so far, much appreciated. Im kinda dropping facts in as i go along and i appreciate thats arsey but i wanted an unbiased view on the car before i incriminated myself further!!
If a vxr is about £8-10k and thats the budget what matches or beats in in a similar category?
Also at similar performance and running costs (and price) what 3 doors make good alternatives?
I appreciate that this is very vague so far.
The spark plugs Vauxhall supply as standard are barely up to the job, start upping the boost at all with a remap and they get blown out. In order to run a remap with upped boost, you need to recap them to stop them blowing out the spark, and watch what model they supply you. There are several different makes you can end up with when ordering from VXL, and only one of them is actually up to the job.
In that case, in Vauxhall's defence, is it their problems if the spark plugs overheat if you modify the car otherwise in accordance with their specifications? Unless of course you're saying that there are numerous cases of them failing when the engine is completely stock? If I had a remapped or whatever car, I wouldn't rely on the manufacturer to support it!
Just sayin'![]()
