Ah in comes the OcUK motors traffic police to tell you about how bad your driving is.![]()
If you keep your head in your rectum then you might just suffocate
Alternatively, if the OP didn't overreact like a sissy girl then the other car caused an accident and should be reprimanded for it![]()
Needs replacing anyway by the looks of it - if the rest are like that you should get them all done.
Why would someone else going quickly cause you to drive up a bank? Unless you thought they were actually going to hit you or were on your side of the road??
Berger said:Now whats cheaper, a new wingmirror or a new tyre.
mattyfez said:Needs replacing anyway by the looks of it - if the rest are like that you should get them all done.
Just demonstrating a run of bad luck probably.
If you keep your head in your rectum then you might just suffocate![]()
when I've replaced just the glass in the mirror before it was £50, think tyres are about £130. They're 235/45/17
