Street Fighter (SFIV, SSFIV, HDR)
wow i can chain seimo now. its not that hard, the only problem is if the first one miss, i cant do the second one and its spaced pretty awkwardly, hence it is really easy to miss.
Its 1200 points. Also 80 points for unlocking Gill and 80 points for the Dip Switch option.
Cheers mate. Whats the best way I can get 400 points? Infact I have 200 points in another account, can you fwd points from one account to another, anyone???
Akuma has plenty of mixup options without the safe jump setup. I think good Akumas will forget about it quickly. Unless there's something more significant that I'm missing...
The thing is that this was one of his main party-starters (unless in the corner) With the added bonus that it carried them quite far towards the corner. A quick example is that this change alone is going to make the Rog matchup a lot more difficult.
After a hp tk if you do a mp siesmo it hits meaty and you can chain cancel to an ex to catch someone trying to move or jump out.
That match is ridiculous anyway. Akuma is still going to be able to walk all over Rog after one knockdown.
Abel
• Crouching Hard Punch returned to Super status where you could use it as an anti-air.
• All Tornado Throws do 10+ more damage. Light: 160, Medium: 180, Hard/EX: 200
• You can FADC the second low hit of Change of Direction now. And that dashing forward afterwards and doing a cr.HP into Ultra works just as fine as if you had FADCed from the first hit. That leaves you at +9 after dashing forward.
YEAH BABY!
Don't buy the Gill unlock btw. To unlock Gill all you have to do is complete arcade mode with each character and Gill is broken and therefore banned from competitive play anyway.
Cant transfer points sadly:( I picked up my points today instore at Game. They have started selling points cards, 400, 800 1200 and 4200 points. I picked up 1200 points for £9.99. I think the 400 was £3.50, not 100% sure. Seemed easier for me than hunting around on the net like I did before.
That's not too bad actually, I only need 400 points so will have a check online later but I certainly don't mind paying £3.50. I was wondering when those 800 points would come in handy! :)
