Any way of forcing a restart or power off? Froze on me for a few minutes now it won't bring up the power menu no matter how long I hold the power button down.
Well, looks like my touchpad is going back. I was in the middle of upgrading to the latest version of WebOS, the pad froze at 12% for about an hour so i tried to reboot and have not been able to get the thing to respond since then. I've tried to charge it overnight and pressing a million different button combinations with no success. No lights come on at all. I wonder if Argos will be able to exchange it or if they will just refund it.
Check out "webos doctor". I think its supposed to be able to recover frpm bad flashes etc. Not used it myself though.
Yes you can fix that with webos doctor very easily.
This thing really needs a back button in the menus and things, such a pain having to close them and repeat your steps just to go back.
You're discovering the many annoyances with the brick.
iPad VS Touchpad Dimensions said:iPad 1 3G: 243 x 190 x 13mm 730g
HP Touchpad: 240 x 190 x 13.7mm 740g
I keep seeing people call it a brick, do you refer to the ipad 1 as a brick too then? Yes it's no iPad 2, but it's not a "brick"
dont have the pad but on Pre you use swipe area and gesture from right to left is used as a 'back' option (?)
.I think it's more in reference to its weight rather than the form factor.
For everyone reporting bad streaming, remember the Wifi connection is extremely locked down by default. Think the download rate is capped to something stupid like 64kb/s
This can be removed via a simple patch (see http://forums.precentral.net/hp-touchpad/293028-new-touchpad-heres-your-get-started-guide.html )
