No worries, I was curious on your OS. As I said, it's a well known bug. On ejecting from USB Mode /media/internal/ doesn't want to remount properly so any new files are not detectable by webOS until a full remount. Anecdotal, but most accounts I've seen are W7 x64 as the OS, but that's probably for the obvious reason.As per my edit, I'm not running w7 on my desktop. Sorry, I was miles away.
For me it's starting to make me wish I had put the money towards an iPad or Transformer instead.
The more I use the Touchpad the more frustrated I get with, but it's confirmed in my mind that I do want a good tablet.
for the bargain we paid for it though it still must be a decent enough buy.
Any updates on the dicksons refund yet?
Lost count how many times that has had to be said.
If anyone does find alternate methods as well then do post them. Definitely worth getting the Box account though because it is 50GB for free.
Gah what the frack! How are you supposed to transfer over 720p MKVs onto the device when it's formatted in FAT32?!
Why does everyone want to play 720p files when the screen isn't even close to 720p...
Just seems a waste to me as a decent avi conversion is fine on a low resolution screen.
I've installed all of these. Also done the ##logs# change and also overclocked to 1.5Ghz.
ad blocker (or max block - one or the other NOT both)
remove tap ripple
Increase Touchpad Volume (lite)
advanced reset options
faster card animations hyper version
increase touch sensitivity and smoothness 10
muffle system logging
quiet powered messages
remove dropped packet logging
unset cfq io scheduler
unthrottle download manager
private browsing
EOM Overlord Monitoring
You should notice a difference as soon as you install 'muffle system logging'. You can notice a speed increase by tapping the app draw button fast and you'll notice it is instant and responds exactly to your taps and doesn't take a few seconds. I didn't do them in that order by the way.
I've just installed KalemSoft Media Player to play MKVs but as I said, you can't transfer anything bigger than 4GB onto it because it's formatted in FAT32.
edit---->
Thanks for that post Chillimonster, will give it a go.![]()
Did your Adverts get blocked?
If anyone knows how to reset everything (software wise) I might do that and start from scratch.
rp2000
I'll look now.
You should just be able to use WebOS Doctor or just remove them all through Preware app.
edit---->
Yep ads do seem to have been removed.![]()
Yeah I used ad blocker
Click here, there should be an advert inbetween the 'General Football Chat' forum and the 'General Discussion' forum.
I just tried in IE and there was then on my TouchPad and there wasn't. Just looks like how it does in Chrome with AdBlock installed.
