Cheers it does work! Also I noticed the snapiness in going into the Launcher now. I might install the other preware bits that you did as well.
rp2000
Oh my godddddd, there is an OpenTTD app!!!
just seen the same thing!
wonder if it works ok with touch
I'm going to do all the tweaks and good stuff this evening.
Even though in fairness, I don't really find it lacking when it comes to performance, certain things are a bit steady but overall it's quite fine.
Feel free to try whatever you like. The patches are easily to remove right inside preware. Have no fear, you won't break anything. Even if you somehow managed to be the rare exception, salvation is one run of webOS doctor away.
My only whinge which is petty is the usb connection is upside down in relation to all my other devices DHD etc
What did you use to do this? Also the player discussed earlier Karim or something does avi fine. Its not pretty but it works when I tested it.
No, all allocated bar 3 I think and I have already emailed the 3 lucky people on ocuk tonight who can have them at cost.
However, I have been checking my orders with BT business and it would appear that I may have another valid order for 6 more but is awaiting security checks. I will contact them tomorrow and if I get those, all 6 will be going to ocuk forum members at cost.
