Thought you might find this comments from the HP UK boss interesting:
http://www.theregister.co.uk/2011/08/26/hp_pc_alive/
does anyone know how you can get the arrow keys to work on the keyboard?
Hunter said: "The sheer scale of interest in the discounted products took us a little by surprise. We are now working on ensuring everyone that owns a webOS device has a positive experience."
anyone found a nice RSS reader that does sync with Google properly?
Get NomNomNom - its sooo pretty!
Am I right in thinking no-ones managed to get AVIs playing back on this whilst not connected to a network yet?
Thanks, this is much nicer than that Mosaic app. Though it seems to suffer from some annoying lag/pauses when scrolling left and right through the stories.
Unfortunately sluggish performance seems to be a fairly common feature of webos apps.
Nope, I think the full version of the KalemPlayer app should but it's about £6 so I can't be bothered to test that theory
Hopefully they'll roll out .AVI support at some point, seems a ridiulous omission.
I'm using Kalemsoft Media Player (Beta) on my tablet (found here - http://kalemsoft.com/betas/) and their server on my computer.
I'm not really sure how it works, all I know that it does work and is very quick. Once you select the avi on the tablet it opens up almost immediately.
It's worth trying. You need to install the beta through WebOS on your computer.
Will try that later on and let you know if it works OK. O've been using tvsersity via flash and it's extremely laggy so hopefully this will be the better option.Just overclocked it to 1.5GHz, feels a lot more responsive![]()
How do you do that?
Have you sorted out Preware yet?
If so it's as simple as this -
- On Preware's home screen, type "Govnah" and hit enter.
- Select "Govnah" and "Install".
- If you have not yet installed a replacement "Kernel", on Preware's home screen, type "uber" and hit enter.
- Select "UberKernel" and "Install".
- Restart your phone as prompted.
How do you do that?
