70 should be ok but check with an expert overclocker, 90 would be way too high for my liking. Check for a better cpu cooling fan or push pull scenario, make sure to have adequate case cooling, take the side panel off your case in warmer ambient temperatures.Hey guys,
I've overclocked my CPU to 4.2GHZ atm and im getting max temps of 70 with an a50 cooler at 100% load.
I'm using core temp and every so often it shows that one of my cores rises to 98C for a second!! I'm worried.
Any advice please.
Was you gaming or something then?, how did you check the core temp temperatures outside of gaming, do you use two monitors and have one showing temperature software?.I'm using core temp and every so often it shows that one of my cores rises to 98C for a second!! I'm worried.
What was you running at that load?.at 100% load.
Something would be wrong and you would risk cpu damage in the short term i would think if these temps are at idle.
I was running Prime95, so the cores were at 100% load. Also I only get 98C for a split second then it goes back down to 60C odd. It also does it every so often.
what is the cpu voltage??
download cpuid cpu-z and it will show you there, aswell as showing you in hwmonitor.
maybe that's throttling back to protect cpu?, i'm no expert but 70-75C would be my personal target, probably not dooable on standard water cooling kits?, nice overclock though.I only get 98C for a split second then it goes back down to 60C odd. It also does it every so often.
I set the voltage to 1.340v. Although on CPUZ its showing 1.264v. ;L
higher core votlage higher temps,, lower voltage to 1.300V and check temps
post back
no mate bsod are natural when trying to overclock
66-70C is fine mate
enjoy
PS: things like tidying up cables (cable management), extra case fans, better quality case fans (high cfm) can all help to reduce CPU temps, what cpu cooler are you using now?
but if i was you i'd just stick with this,
yeah cpu cooler make a big difference but also the motherboard,
more expensive motherboards tend to be better at overclocking, cheaper ones have less features etc. If you put your chip in better motherboard it might do better or it might be the luck of the draw with the cpu ( not all cpu are born equal) and it will always perform at 4.2ghz
In my case i think my motherboard is stopping me going to high speed so im stuck at 4.4ghz which im fine with tbh
In most games gpu will have bigger impact on performance than what speed your i5 is set at, because really nothing pushes an i5 2500k too hard game wise.
im using hyper 212 cpu cooler, cost about £20. But im using lower vcore hence lower temps.
Go into windows experience index, on the left side click on Advanced tools, and at the top of the page there is an option to clear all windows experience index scores and re-rate the system (Force a complete re-run of windows experience index tests).won't let me update windows experience index.
