Hehe cheers VOoDOoWOW!!! Those cable holders are freakin amazing!!! Pure gold....I mean copper!!! non-ferrous metal!
 I might be revising them so they go straight up to cover the sata cables completely & sleeve the lower ends & make sure there isn't any slack.Ah okayI didn't notice the power button at first, but now I see it
Again, looks great!
 It is a small switch.Thanks alex2k10, had to order from an iffy shop (iffy for their business practices against other shops) for white led strips but hopefully I should get them asap so I can see if white is better for the fan holders or not, heard a fair bit of bad about the place but was the only place selling the white ones & not warm white.Wow really nice work. The cover for the cables is so meticulous mind you looking through the log I would expect no less.
Also the light coming off the fan surrounds as you say is so unique and 1 of a kind.
Can not wait for final pictures of this.
Maybe you could in time mate, best to absorb as much info as possible on case logs, me I just took apart my lian-li case & checked it out thoroughly to see how it all forms & fixes together & made a quite rubbish first case lol, then a 2nd, then a 3rd which was nicer but still plenty of room for improvement & now this beauty, so I think I've improved an incredible amount since my firstWish i could build anything like this
Great build the detail you go in to is outstanding tbh nice one
 now I can get an idea, design it & figure out a way on how to build it, no way would I have seen myself doing something like this 3 years ago lol
.Thanks MCMLXQuite simply, stunning!!
, I also had the iffy RGB strip working but I really couldn't figure out what I was doing right when I had it working so was completely hit & miss but should have no probs when the new cable comes, I took it to the scroll saw instead of grinding it slimmer on the disc sander (lesson learnt on that now
) think I'll keep it set on orange light as it's closest to the copper & it also creates a very cool effect on the fan spinner pieces I made but I'll have the option to pick quite a nice bunch of colours or even have it slowly fade into all the different colours which is quite nice
 or switch them off if they get irritating, the apollish fans I enabled the rear 2 the front one is too bright & makes the front look wrong so this makes it look nice with just that one switched off.
 after making that optical tray & the yin yang 120 I know I can do metal marquetry with the scroll saw wooooo
 with 2mm upwards I can do it nicely, 1mm it's surprisingly more tricky probably because it cuts faster & easier.  I like to do a side project after a big one to ease myself back to normal so I slow down the modding withdrawels by not having a sudden stop lol.
 (maybe with a larger version in the centre to support the bearing... if it needs it)
P.s you can never have too many photos.
I hope so, cos it won't be the same on here without reading about a Waynio build.
Nice idea making it a part of the case I'll think about that mate, nice oneCan never have too many pictures of that badboy!! It's simply stunning mate!
If you're going to do a lazy susan, if it were me, I'd do one the same size/shape as the footprint of the case with the circular bearings in the centre (so it's like a circle with extensions) so when it's where you want it, it sits square with the case and doesn't ruin the lines, but still rotates when you want it to...
Maybe you could put those feet on the bottom of the lazy susan so nobody would ever know it was there(maybe with a larger version in the centre to support the bearing... if it needs it)
That's my idea, don't know if it's doable, but I think it sounds cool lol![]()
 I'd have to make a braking thing for it though so it can stay locked in position when needed, think I'll get busy on the design now to see if it's doable, would make a great feature
.Thanks KD the lights are UV so purple but in the photos they do look blueThat is incredibly stunning!
Nice to see it all come together! Just out of interest the lights look Blue, are they blue or purple? Because they look like the blue I get off of my purple LED's xD
kd
, not keen on the rear 2 but the front one looks ok really through the grill.The side panels really set it off well. I have a feeling it's going to look stunning when you get rgb sorted.
 Thanks Alex.It's always been me looking up to other modders & now starting to feel somewhere near there level but on electronics & motors I'm still completely unevolved lolEVER!!! Ecspecially of this beast. I love how much attention to detail you have sir. You have passed the journeyman modding test and set the bar higher for those who follow!!!!
 so I have lots to learn still even in fabrication to be honest
.Nice job on the cabling, you had me worried for a minute.
Have a sneakinf suspision that you're going to get the end of this build and having finished it feel a craving to start something else.
 It was quite unruly
 I'm really considering re-making that sata cable hider so it completely covers the wire side for the sata cables.
 buying everything I think I need for a project is just too much for me unless I save up for a while so maybe focusing on 1 part of a design at a time is the way to go for me, I am really looking forward to making what I intended to make on the pci/io piece now I have that scroll saw, should be able to make those perfect now & easily & it's going to be weird to justify making more cases as I think this one is going to be in use for a very long time but it would be cool to make a mini version of this
, who knows I might start making them for others where they are in a plain state like a Lian-Li case ready for modders to put their own style into it but I'd have to get clued up on pricing so I don't sell myself short & don't overprice.+1!
Seeing updates in this thread was the best part of Case Central![]()
 Cheers EniGmA
 system side, cable side & storage side
 so the 3 white & 3 uv led strips will go in the mod bits box for another time so now I have to design & make the new slim boxes.  Already had 1 30cm RGB strip so just had to order 2 more & another control box (it lets you run 3 strips through it) so if I push myself I should be able to call this complete by the end of the week & maybe another week to make the lazy susan
 or if I have the lazy susan as part of the case then 2 weeks I'd guess.
 I redesigned the sata hiding piece with a little reinforcement & extra length for a complete cover & 3mm extra space for depth & did my best to make sure all of the pieces are the same as each other but that sheet metal bender is difficult enough to line up 1 piece ready for bending so had to do 1 at a time which is why they lack perfection, anyway now I'll be able to have the cables fully extended & fold up excess length inside the piece & finished designing & making the new slightly slimmer RGB control box so up next is sleeving the visible parts of the sata cables then put these parts back to use again
, the only reason the original box was too big is beause of them cramping the cable work so could have been a good bit slimmer but because of the bad cable work inside these things I had to make it longer but at least I can cram it under there now & have RGB lights in the storage section also
 I also placed a cut to size piece of 1mm foam board for under the pcb so it doesn't get any contact with the alu.Is that the phobya rgb unit you got. if so i been looking at that but have yet to see anyone use it yet.
.Sounds really good wouldnt mind a video of the lights once you fit them to see the effect they have on the case.
Also i think you have made a bespoke piece of art and not a computer case.
 so the cables are tucked up so it all looks neat now, I even made an end cap that I'll stick on the top, just need to brush it, lacquer it & then stick it on top.
.Well i shall look forward to that dont worry about vid if you can not get one. Dont want you to spend £300 just to get a video lol.
 I found out why 1 of the 60cm strips were working temperamentally & it had broke around the solder points, the other worked ok but on the cable side, 2 of the 30cm ones inside the fan holders worked but the 3rd didn't & couldn't figure out why so I've had enough of these garbage RGB strips from phobya & have ripped them out & thrown them aside never to be used or sold as they aren't good enough to sell IMO, you was wise to look into other people using them Alex
 can't believe how much time I've wasted with them, I only originally wanted subtle lighting anyway so I must have lost the plot a bit going fully & brightly lit up
), just wish I went this way originally, would have saved time & money.
 I did start taking some pictures of the bottom section but the battery ran out so couldn't finish & get them on the pc, probably for best anyway, would be nice to make the next update the final photo shoots
