dewalt has gone so down hill i will never buy them again..
Yep.
Milwaukee are another good make.
jinxpad
The PSB 650 RE Impact Drill you refered to in your post is a hammer drill. You can switch the hammer action on and off as required.
It will be fine for drilling holes in computer cases as well as normal diy jobs. A cordless drill of the same capacity is going to cost the wrong side of £200.
really that much huh? That's pretty crazy, but it's good to know that the Bosch I was looking at will do the job. Added to shopping cart!!
B and Q are doing a great cordless 18v makita hammer drill set for under 100 quid and i have been using them for over 5 years..
Thanks for the input, and I think I'll be going with the Dremel 4000 and the Bosh jigsaw max recommended.
I'll basically be following this guide for my mod:
And the jigsaw just makes much more sense, and like I said, never know when I might need it again
Would the dremmel be able to drill the holes I need as shown in this vid? If not then I still need a nice cordless drill specced![]()
You are going to need a metal file to clean up your edges, a half round one if cutting circular holes. Also invest in copious amounts of 2" masking tape and cover everything which could get marked as you lay the case down, move it about etc. The 700D will scratch very easily if you are not careful, particularly the case edges.
With regards to the filing, can the dremel be used for that with the right bit?heheh oh yes, much tape will be purchasedWith regards to the filing, can the dremel be used for that with the right bit?
What's the difference between: Dremel 4000 Rotary Tool Kit (4000-1/45) and Dremel 4000 Rotary Tool Kit (4000-4/65)??
It sums it up there nicely
The number of accessories you get with it basically... Go check out the dremel websiteIt sums it up there nicely
1/45 http://www.dremeleurope.com/dremelocs-uk/product/2709/395/dremel®-4000/dremel®-4000
4/65 http://www.dremeleurope.com/dremelocs-uk/product/2709/396/dremel®-4000/dremel®-4000
Basically look at the content tab...
kd
Very much so, I believe they are owned by/division of Atlas Copco. We've had some 7" Milwaukee angle grinders going out on hire to oil rigs for some 10 years are still going strong.
If there are any specific cutting/sanding etc.. accessories your after if I get chance this week at work I'll check through some of our abrasive manufactures catalogues and see what they stock (pferd/draper/metabo and some others), might save you a few quid as the company I work for are distribution agents so no tax + between 20-40% off list price.
Depending on intrest, and when I get MM privileges, I might start putting up select power tools at the reduced cost I get them for, though sorry no dremel from what I can remember, just the draper/metabo/makita alternatives.
