wasnt 6970 released December 15th as i got it on first day it was released. of course if amd release september im sure it is going to be low end first as they usually do same as with 6870
Thats the first time AMD or Nvidia have ever done so, and its purely the lack of 32nm which both companies meant to be on.
THe 6870 was craploads less work than the 6970, the 6870 is a tweaked 5870(though very nicely tweaked), the 6970 they ripped from a 32nm design, backported to 40nm, cut down and had to lose various parts of due to lack of space.
Its possible the not so high end will come out first, but the 6870 most certainly wasn't "low end" in any way shape or form, we'll have to see though.
The 6970/6870 weren't planned years in advance as normal so very hard to say what AMD will do next time, they were also vastly different to every previous gen in performance.
Every previous gen you have a 9700 pro, 9500 pro thats half the speed, and a 9300 pro thats half the speed again. there 8 pipelines, 4, and 2. Later on its 800 shader 4870, 400 shader, 4670, 1600 shader 5870, 800 shader 5770.
With the 6970/6870, what you got was a high end card with all the compute stuff included with a 380mm2 die size, but dramatically lower gaming performance per mm2. Still faster and not much more expensive, but essentially you have the ultimate gaming oriented architecture in the 6870, and the 6970 which isn't close to twice as fast as every previous generations split.
So this gen, will we get a 7970 with X shaders, and a 7870 with x/2 shaders? or will we get a 7970 with all the compute stuff on die, fast but fairly big, and a 7870 thats vastly smaller, lots of compute and other stuff removed, but way more than half the speed of a 7970........... AMD knows, no one else does.
