A few options would be good reallyReally depends on where you plan to put it. Most cases will probably do what you want. Are you concerned about looks / noise ?. Is it going to be in public view or in a cupboard somewhere ? How many hard drives for the case, hot swap or not ?..
Oh and connectivity (eSata / USB 2 or 3 / Firewire) ?
Lots of questions but better to give a decent recommendation.
Cheers
RB
eSata is more than enough, hot swappable overkill, and scalable. My idea, long term, is one of two things: a rack solution with a 1u server, and an nu HDD box, so looks are irrelevant as it will be in a cupboard with gigabit ethernet links. That said, it wouldn't have to be a rack mounted hdd box as others would happily fit in a small rack.
I'm also looking at an option for nice looking hardware that can go in a central console as part of a home cinema set up.
Do you do this kind of thing for a living?
