 - 30 Aug 2011
I thought i'd post you some pics and comments as i built my new system which i had discussed with you previously...
Its the first time ive posted something like this so sorry if i make any errors or miss anything!
The kit - £700 worth
The case - Coolermaster - didnt come with a 3.5 - 2.5 adapter for my 2.5' SSD
Power supply fitted at bottom
Bluray drive fitted and front view:
The motherboard - MSI P67A GD65
Memory - Kingston hyper x 8gb
Motherboard and processor fitted in case:
Cpu Cooler - way bigger than ive ever seen! fan was i ***** to fit to the heatsink, no instructions included.
As you can see the cpu cooler only just fitted in the case with about half an inch clearance!
Cable management not my best strength!
Gigabyte GTX560ti fitted, needs 2 pcie power plugs. couldnt use the HDMI connection as it was too close to the edge of the case, silly design fault by coolermaster!!
all fitted and powered up to see if it works ok:
Relieved to say its all working and windows 7 installing... this is how it looks in my cabinet at home!
Any questions please feel free to ask!!
