- 16 Nov 2010
- Swimming in a lake
The project is finally here!
Introduction
I feel the project requires a bit of an introduction. Having built my first PC from parts only a couple of months ago, the bug has hit! Having spent many a day on the forums now, I've decided to start a new project! With both me and my fiancee at University and making the most of dual screens, I've decided to build her a base spec pc capable of meeting her requirements as her laptop's struggling to power the dual screens for internet browsing/office/iTunes and the light multi-tasking that she does. Now having just spent a fortune, especially for a student, on the last build there's not much money floating around for the new build! The challenge is slightly steeper with a bit of history, as I've spent my life doing next to no DIY! Managing to get a D in GCSE graphics. The most I've really done is the recent flat pack I've assembled (at 19) and frankly I've decided it is time for this to change! As such, and partially inspired by G-Dubs' Car Boot Project I took a trip down to the local car boot today... Thing is though, going to the local car boot (and the largest one in the county) all I could find was one computer with nothing to it's name, and frankly even the case wasn't worth getting it... So I went for a local trip to the Bay... £50(ish) later and I've got some old P4 HP, which should be in the post tomorrow, and arriving soon
But yeah, the same basic theme, of picking up parts dirt cheap off of the Bay/MM/car boots and building a PC that does the basic requirements. Going to customise the case to be a nice pretty case for the gf.
Going to keep everything else under the mat for now so we can see how it goes But yeah a similar Dubs-esque kind of idea - all credit where it's due, and I'll be relying on basically all of the OCUK expertise, to make sure I get out of it the other side with a working pc, 10 fingers and 10 toes
Now, as for the name of the project, I had some great suggestions, but in the end have decided to go for something decisively simple... Ay, is an abbreviated form of the alias the Fiancee uses online, so much like kd for myself... Makes all things fairly simple
Now a bit of an update from the original intro... The Bay PC, is arriving tomorrow, on a long delay from the seller -.-
As such, as I'm up in Norwich at the moment for Uni, I decided to go with the fiancee to the local Car Boot, and see what we might find... All in all I must have spotted a good 5/6 pc's... and in the end settled for getting a god-old pc, for a fiver as there was nothing that would inspire me hardware wise so I thought I'd grab a spare case... So £4 later, I have a bunch of old parts, that I may be able to use at some point, and tomorrow I have yet another PC arriving, that again I hope to use at some point...
Also this PC gave me a great opportunity to test out the new tools!
This is everything I picked up from B&Q/the boot sale this morning, figuring this would pretty much be everything I need...
Anyway, after the boot sale, I worked on taking apart my £4 PC.... and ended up with a bunch of parts
And a very filthy case
At this point, I kinda forgot the camera existed and got stuck in
So apologies, but basically at this point I washed down the case with warm water and some fairy.
Whilst I was working the fiancee made me a sammich
I then started cutting holes
Thought I'd start off with some basic cable management holes for now, as this was the first time using the Dremel!
And always wear eye protection people!
Just in case this happens....
Again I got a bit carried away with the Dremel, and forgot about the Camera... Anyway, I realised that the original line I cut above, is actually under the Mobo - Cue swearing.... And started again! This time I managed to cut out in the correct place, and cut out some odd bump, that frankly from my point of view had no purpose, and just looks odd....
As you may have noticed, this was the point the heavens decided to open - Cue more swearing, so have had to stop the Dremelling for now
I also realised, that perhaps I shouldn't have bothered cleaning the case before cutting holes out of it... and should have done it after... Anyway, due to the weather, and needing to clean the case, it got moved to a new location
Thankfully we all have en-suites in my Uni flat... as it left quite a lot of dirt...
Anyway, that's been washed away, and thankfully I reckon there's enough ventilation through the fan in the Bathroom that I might be able to work in there in the winter when it's ****ing it down so long as I can get some card or a sheet or something to work on..
This is the final hole, with mistake line next to it! Hole is quite wonky in one place, but didn't think it was bad for my very first time with the Dremel!
As for the rest of the project, well you might have got a hint of the colour scheme, from the borders to the images! I apologise for the giant leaps in images, just got carried away, and next time I'll try and sort out better lighting for the photos!
Lessons learnt for next time
Unfortunately we may see a delay in updates for a couple of weeks, as all the stuff for doing the project will be at my student house, and we don't start properly for a couple of weeks, but this'll be a good taster! Frankly with the new case arriving tomorrow, I can't even say whether you'll see this case again!
Any advice, etc.. to avoid breaking the disc or anything else would be appreciated!
kd
Introduction
So apologies, but basically at this point I washed down the case with warm water and some fairy. Whilst I was working the fiancee made me a sammich
- Work with the Dremel - working against it results in breaking the disc
- Start off with a faint cut with the Dremel before going all the way through - otherwise you end up cutting wonky!
- Don't forget the camera!
- In pictures, get better lighting!
kd
