10.3 HQ mode
The headset’s High Quality (HQ) mode enables wide-band wireless voice communication with the PS3 system. It uses the headset’s dual-microphone design to enable proprietary PS3 system-based noise cancelling, and provides better radio frequency interference rejection when it is turned on than when it is off.
By default, HQ mode is on when you first pair your headset and PS3 system.
HQ mode and noise cancellation features are only available for the PS3 system, not with other Bluetooth® enabled devices or mobile phones.
To turn HQ mode on or off:
- On your PS3 system’s Home Menu, go to [Settings], then [Accessory Settings] and select [Manage Bluetooth® Devices].
- Select the headset from the list of registered devices, press the triangle button, and then select [Information] from the options menu.
- Access High Quality (HQ) Mode.
- Select On or Off.
