- 4 May 2004
My 8800 finally died again and it's time to get a new card. Is there anything of similar or better spec for around £60 (new)?
Thanks
Thanks
erformance than the newer cards? Would my CPU hold me back anyway from a semi-upgrade to something like a 5770 or better?Thanks for the replies.
I've got a Core 2 E4300 at 2.4GHz. It was a bad clocker (heat) b/c of some issue with either misreporting temps or the IHS contact being with solder not paste. 2gb DDR2 ballistix, WinXP, Corsair 520w and 1280x1024 19"
I remember reading about the 4850/5770 being good cards but it seems they are a little too old to find in retailers nowadays...
Are those cards on the refurb list much better on priceerformance than the newer cards? Would my CPU hold me back anyway from a semi-upgrade to something like a 5770 or better?
The GTX460 is a great card, I will admit to that. It is the 8800GT of this generation. But it requires two PCI-E 6 pins to run and the HD5770 is only the tiniest bit slower and for around the same price and only requires ONE 6 pin adapter to run and uses a LOT less power.
The reason I went with is because of the above reasons, plus I have one lol, and never been happier!
and only uses around 40 watts more when gaming, hardly a LOT more power is it
According to some websites that I have been on, the 5850 is on par with the GTX460 and the 5770 is just under the 5850 so not that less powerful.
Plus the 5770 is highly overclockable. I have mine at 990/1500 stable and under load even though its the single slot version from XFX only hits 65C which I think is great and under 100% fan speed ofc.
My 5770 is more powerful thanks to the OC than a gtx460 and 5850!
Just make sure you have a decent case for cooling and a good PSU!
Done!
I believe in buying lower than you want, save money, overclock and get what you wanted in the first place for less money.
the hd5770 is a great little card that runs brilliantly with a standard quad or good dual core and will give (with some good memory i.e. ddr 1066 or ddr3) great frame rates at 1920*1080 (HD level) for at least the next year or so.
It is a great little card for less than £100.
A GTX460 is minimum £125 on OC, but the hd5770 is around £80-£90 elsewhere (£125 on OCUK) and will give great performance as the GTX460 will but at a lower price.
This is the reason I love the HD5770 so much!
