Just took the plunge and pre-ordered this![]()
Its gonna be a pretty big plunge... the price is gonna be dropping on this game very quickly.
Nothing stopping them recompiling the engine with tweaks later on, unless it's not THEIR engine?
aparently you can just open the .pak with winrar drag the file out edit it and then drag it back in aswellI'm using "Total Commander". You can view (F3) and edit (F4) files inside archive and it will unpack/repack it for you.
Edit files with Notepad it will save xml files integrity.
fov 92
All you have to do is to pack your edited files back to Data0.pak
Data\Skills\default_levels.xml - fov and strife speed.
Data\Menu\Movies\IntroMovies.scr - comment everything with // to disable intros, that might fix the black screen problem at the start for some.
Data\Scripts\varlist_blur_camera_motion.scr - change all to 0.0 to disable motion blur
Data\Scripts\ - there is some *glow* and *lighting* files you can mess around with to try to get rid of bloom.
Been on the wall whether or not to cancel my pre-order the last few days. Started hearing very good things now though. Shall be keeping it.![]()
nothing to stop you altering it either.
FOV is inside the datapack here Data\Skills\default_levels.xml - fov and strife speed.
Zomg gona try this when I get home, thanks for the post hate looking through a letterbox. Is there anymore options that you have found that can be changed?
just saw someone posting about it on another forum i guess the game should be fairly easy to mod to make it more pc friendly if the devs arent going toWho hard codes the FOV to 65? Muppets
Can someone please send me a file with it set at 82?
or uploaded here
http://www.datafilehost.com/
THANKYOU![]()
