- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi all.
We have now got a great deal for you guys. This is in essence a Corsair H60, as it is manufactured for OcUK by the same company who make the H60 for Corsair.
The only difference is you have the freedom to choose any fan you want, oh and you get to save a few quid too
OcUK H²Flo Liquid Cooler Cooler (Socket LGA1366/1155/1156/775/AM2/AM3) @ £38.99 inc VAT
The OcUK H²Flo Liquid CPU Cooler is a fantastic product aimed at medium to high end CPU cooling, with the power to slay any overclocked CPU temperatures succesfully. The cooler houses a large surface cold copper plate to ensure all the heat is drawn away from your CPU and transferred to the sealed liquid and the pump then transports the liquid round to the radiator which then cools the liquid back down to enable the liquid to recirculate back to your CPU block to again pull more heat away. All you need to do it add a fan of your choice to the radiator and your CPU will be cooler than the next Ice Age.
- Socket LGA1366 / 1155 / 1156 / 775 / AM2 / AM3
- Radiator Dimensions: 120mm x 152mm x 27mm
- Fan Support: 120mm x 25mm
- Cold Plate: Copper
- Radiator Material: Aluminium
- Thermal paste is pre-applied
NB: No fan is included.
Only £38.99 inc VAT.
ORDER NOW
ORDER NOW
