I got the grit paper at work mate, (painter + decorator). Used a few drops of water and a piece of glass as a base, 10 passes back and forth, 10 side to side, checking the cpu/cooler base with a brand new stanley blade to see how level it was. Took about 3 hours for the cooler, 2 for the cpu, im quite used to sanding things unfortunately.![]()
Assuming he doesn't use hyperthreading his i7@4Ghz will give maximum value of 64GFlops.
IBT is a double-precision (64 bit) program so it is always 4 Flops with mutli-add operations.
So for i7@ 4Ghz (Quad core)
4 cores x 4 Flops x 4Ghz = 64Gflops
49/64 = 76.56% which is still high enough.
For any dual core you just replace 4 cores with 2 cores and for single core it is 1 core.
E5200@3Ghz
2 cores x 4flops x 3Ghz = 24GFlops
Those values you quoted I believe are the real world predictions by Perspolis in his case. So it doesn't apply to everyone as each case is unique.
Your friend should be able to get over 50GFlops by choosing custom and tweaking memory or closing some background programs. As xsisitor, another fellow ocuker stated, it depends on the algorithm aswell and how well it is optimised for cpu processing. The algorithm in IBT or LinX is the LinPack algorithm/program
The greater an algorithm is optimised the greater output from cpu will be in basic terms. Hence in real world we can never achieve the theoretical maximum but can only try to get as close as possible.
I tend to hit 51 ono gflops on my i7 at 4ghz, same at 4.2, which is proving to be a bit trickier to get LinX stable.
thanks guys for the response![]()
Don't think it matters as long as your ram is not exceeding the rated 800MHz.My RAM is just value stuff, came from "another BIG online retailer", but i remember reviews at the time saying it had been 'clocked to 1000.
I'm looking forward to this... someone explaining to me what all these timings etc mean!
