Dead Island FOV & Graphics Tweak Tutorial for PC
This game worth buying?
I like there to be quite a bit of character development in games and this is what gave me some temptation with this, or is it just next level new weapon quite paper thin form of advancement?
The tweaks menu no longer closes automatically when you check/uncheck an option
Shadow maps: You can now set the shadow map resolution to 512, 1024, 2048 or 4096
Field of view: Expanded selection of values ranging from 62.5 (default) to 90 degrees
Added an option to enable overcast weather
Fixed a bug that could cause the program to crash when selecting non-option menu items
Is this safe from a VAC ban?It’s highly unlikely. The tool doesn’t modify any of the game files directly, which is what VAC looks for. It simply extracts the required files from the game’s data packs, puts them in the Dead Island folder in “My Documents” and makes the necessary alterations.
Now, the game does install a keyboard hook and does run a routine to detect if Dead Island is running in the foreground. If it does detect DI, it prevents multiple keystrokes from being processed, otherwise, it lets them through. It doesn’t send keystrokes, inject code or do anything else bot-like, so I’d be very surprised if it resulted in a VAC ban.
Does the helper need to be running while I’m playing? Only if you use the “Prevent keystroke repetition” option, as it installs the keyboard hook. All the other options, like overriding the field of view, disabling motion blur, etc., work without the helper running once they’ve been set.
Is this VAC safe ?All this tool does is manipulate your configuration file, which you can do yourself in Notepad. So no, can't possibly result in a VAC ban.
100% safe. I can actually play this game now, lol
Not sure if it's already been in here but...
When I load Dead Island after a format - It just black screens now for about a min before the menu shows :/ - any idea?
.Some users are experiencing ridiculously LONG load times when doing things like loading the menu, game, etc. It can literally take over 5-10 minutes for some people. Oddly enough, this may relate to error logging that is done by the game.
1) Go to My documents\deadisland\out\logs
2) Right click the crash.log -> Properties — and mark the file as “Read Only”
This will prevent the game from writing data to the log because it is no longer writable (hence Read Only). Oddly enough, this may fix your long loading times
Will it get you VAC banned?
is this game worth a punt? i know there was a lot of doubt about the game and overall quality? whats the single player like, is it worth playing or is this generally just better coop.
