It's easy to solve, just turn off flash in the browser options. You can always count on Adobe to do their best to screw up the user experience![]()
But then you wont be able to watch flash?
Wifi is working (more or less) in cm7 from the UI as of this morning thanks to amazing work by dharix who did some creative module source tweaking to put together something that would build against the cm kernel. It works with cm userspace and is checked into the repo.
There are still big issues to be addressed-- lots of ioctl errors in logcat; if you hit the power button to sleep, the wifi won't come back when the rest of the tablet does. Also, some apps crash or freeze the screen, though this could be a problem with the lack of sound locking things up. Signal strength is not being reported correctly either.
There are probably more huge problems to be discovered as not enough of the team has gotten it going. But y'know, it's a start, and the browser is really fast, the twitter client/widget work, mail app, weather app/widget works... needless to say anything involving video/sound does not.
.Can confirm that the £1 neoprene iPad case from Poundland fits perfectly.
. It comes in a few colours as well including grey, silvery, bluey-greeny-silvery (the one I got), black, red and pink
Can't get WebOS Quick Install to detect my Touchpad, and therefore can't load an overclocking kernel, etc. Tried on 2 Windows XP 32 bit machines with Java 7 (both machines were recent builds) and 1 x Windows XP 32 bit with Java 6r27. The navacom service fails to start, which I guess is the problem.
I had similar problems and found that it was related to my browser being open - closed my browser and all worked fine. Give it a try.
Thanks but no difference. I've tried after a reboot too (with no applications running), the service still won't start, and no clues given in Event Viewer.
installed the novacom drivers?
Thanks, looks ok. Unfortunately, for me to go to the nearest Poundland I would end up paying x 3 the cost to park
Ordered the offical case from HP at the weekend for £19.50.
. And this one closes!Via WebOS Quick Install yes. I believe that extracts them from the official jar, but is there another source?
this.Have you enabled Developer Mode?
£4 is still less than £19.50. And this one closes!
this.
I had the same issue, I thought dev mode was active as I enabled developer mode when I got it. I then updated to 3.02 and somehow by the time I tied to do the preware install it got turned off again
It should work fine after its turned on again![]()
I think the official one is much better and you can use it as a stand![]()
