Don't worry about 3.0 dude im not,And back to the picture it will be uploaded tomorrow sometimes not sure when yet busy day tomorow.
Ok no problem
Sorry mate having some problems with my camera,So i may aswell tell you now and upload a picture when i can figure out a fix,It's a Q6600 + MSI MS-7360 not sure how good the board is,but cant complain for free![]()
So whats left just cpu now?And im not sure yet may build a HTPC
Cpu and Hard drive, Gfx Card
What are you looking for for your CPU and GFX?
It will be worth holding out for a quad, especially for FSX and BF3, make sure you get a joystick FSX doesn't play too good with the keyboard
Bought many more fans yet luke? lol. I can't judge I have 5 in mine, 7 if you include gpu & psu.![]()
best keep the window open in winter then, no point having 8 fans blowing intense wood burner heat through the case
having said that, a good airflow in the case can drastically lower the temps, load and idle of the major components, a good airflow case can get away with fanless coolers on the cpu & gpu, not that I would recommend spending the rather large amounts of cash on those coolers. and besides that they are usually quite large.
Every other fan has 2 diagonally accross from each other.
120mm fan
That fan is tiny
Not sure about the fans,Though aslong as they do the job who caresI can vouch for the cpu cooler though,It served me well for a long time
