Surely you'll be able to remove the metro stuff with group policy in a corporate environment
MW
Anyone running it in VirtualBox having trouble getting internet access? Do I need to mess about with the adaptor settings? All my other VMs seem to work fine (XP, SuSE etc.)
 may have to try itAnyone know:
1) How to remove the watermark on the desktop?
2) How to get the volume/brightness graphical overlaps on bootcamp to display? They appear to be missing in Windows 8 even with Bootcamp 4.0 installed.
Why do you want todo that, as its just for messing about with?
What version/build of win8 is everyone using??
Won't install for me - says some required files are missing![]()
downloading now, will shrink the main partition in my laptop with win7, is it possible dual boot? also how easy to restore win7 MBR if i need or want to remove win8?
cheers
just playing about win8, looks very good so far! i like it![]()
installed hyper-v and it asks to connect server..........errrr what server? how to add/install guest within hyper-v?
thanks
