Just got my Tamron 17-50mm F2.8 XR Di II LD Asp
I see no issues with sharpness of mine at 50mm f/2.8. It's just a very narrow depth of field, but having used a 50mm f/1.8 for 6 months, I'm well used to shallow dof. The text in focus is still perfectly sharp.
I bought myself a 2nd hand non VC motorised one and got it yesterday. Not had the chance to check for sharpness but I have noticed that the zoom righ is very stiff compared to my Nikon and Sigma lenses. Seems a feature of that lens though.
Ejizz, where did you download the template or buy this from please?
UPDATE, seem to be ok... But I find this lens difficult to deal with in terms of exposure, is it because of the lens Hood?
F/2.8 50MM
F4.0 50MM
F2.8 17MM
The exposures don't come out as easily as the canon kit lens Constantly having to adjust them and also these shots lack contrast, they look flat. I know lighting makes a difference, but even on a nice evening, they still look flat.
How does the sharpness look to everyone now?
field sharpness looks fine to me, I'd stay away from 100% crops and focus charts for me if it's good enough in the real world it's good enough and all this peeping and testing can only lead to disapointment and frustration. Remember sharpness isn't everything some of the best pictures of all time would fail the modern photographers pbsessive definition of sharpness.
Your problem with exposure is confusing me it should be no different to using your kit lens, what mode are you shooting in? If manual what method are you using to get the correct exposure.
Exposure looks fine to me?
Shadows are a bit harsh but thats because the camera's trying to stop the sky blowing out.. so in that sense its done its job.
Thanks all :), I think i'm confusing myself probably all the meds i'm on haha
Again though, what Polarizer size would i need for this lens?
Or a kit bag where all the components work perfectly together, giving you more keepers and less missed opportunities.
Anyway I guess Neil can rest assured now you've given his lens the "all clear".
Indeed sharpness isn't everything, but what ABSOLUTELY does kill an image imo is if the sharpest part of the photo is in the wrong place, how would you rate the images in the below thread, and what would your advice be if any?
http://www.talkphotography.co.uk/forums/showthread.php?t=351399
Calm down, I never gave his lens the all clear I just said test it as you would use it and if it produces the goods then don't go shooting focus charts or pixel peeping at 100% plus.
Not sure what that has to do with this thread and if anything it supports my argument that field testing is all that has required as those shots clearly fail the real world test assuming the poor focus is equipment rather than user error.
More bad advice, in fact it's this kind of advice that will ironically lead to "disappointment and frustration".
You obviously don't understand the relationship of precise AF that doesn't suffer either front or back focus Vs Keeper rate, as a correctly functioning AF will have more margin for error (that inevitably happens by the user and equipment) than a setup that is on the edge of spec, let alone slightly off spec.
I wonder how many poor folks are out there right now taking a picture one minute that's in focus, and the next OOF and not knowing why that is happening, no doubt blaming themselves one minute, and their gear the next.
How disappointing and frustrating must that be do you think?
Well I can tell you, VERY.
Focus tests are pointless unless you test all focal lengths at all distances and f stops that you will be using the lens. A lens that you suspect of poor performance enough to look at a focus test can easily have issues at near and far distance as well as focus shift when stopping down.
