for some reason steam wouldn't login on any of the dongles/tethered mobiles I tried but several of my games would actually work offline outside of steam if I had steam up on the error prompt that no network was found lol (wouldn't work without steam running at all). Unfortunatly others would still says "this game has to be launched through steam".You can play steam games offline.
Had this problem recently when BT managed to screw up and cancel our phone line accidentallyfor some reason steam wouldn't login on any of the dongles/tethered mobiles I tried but several of my games would actually work offline outside of steam if I had steam up on the error prompt that no network was found lol (wouldn't work without steam running at all). Unfortunatly others would still says "this game has to be launched through steam".
Steam Minimum Requirements said:Internet connection (broadband recommended)
A lot of mobile internet has port or routing restrictions that block steam. If you go through a VPN or ssh tunnel/etc you can get round this though.
The trick to getting steam to work of line is to Temporarily Disable your NIC, then switch to Offline mode and re-enable your NIC.
Nate
