What do you need? everything including OS?
Your basketProduct Name Qty Price Line Total
Intel Pentium G620 2.60GHz (Sandybridge) Socket LGA1155 Processor - Retail £53.99
(£44.99) £53.99
(£44.99)
MSI H61M-E33 Intel H61 (Socket 1155) DDR3 Motherboard **B3 REVISION** £46.99
(£39.16) £46.99
(£39.16)
Corsair Builder Series CX 430W V2 ATX '80 Plus' Power Supply (CMPSU-430CXUKV2) £35.99
(£29.99) £35.99
(£29.99)
Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) £29.99
(£24.99) £29.99
(£24.99)
Fractal Design Core 1000 Midi Tower Case - Black £28.99
(£24.16) £28.99
(£24.16)
Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9AD3B1K2/4G) £23.99
(£19.99) £23.99
(£19.99)
LG GH22NS70 22x DVD±RW SATA ReWriter (Black) - OEM £16.99
(£14.16) £16.99
(£14.16)
Sub Total : £197.44
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £12.50
VAT is being charged at 20.00% VAT : £41.99
Total : £251.93
Included a new DVD if your other one is IDE type
The motherboard - http://uk.msi.com/product/mb/H61M-E33--B3-.html - has VGA/HDMI and DVI outputs for the Pentiums HD1000 built in gfx core.
Is that processor better than core duo 2 e600 or e700
Yes,
G620 vs E7200 - http://www.anandtech.com/bench/Product/406?vs=62
It does more work per clock cycle (its based on a scaled back Sandybridge so look past the Pentium name)
It uses less electricity.
Runs cooler.
Socket 1155 board means you can put all the chips in it, i5 2500 etc.
Ok but that's compared to 2.5 e600 is 3.06
Ah you mean a notebook/laptop cpu, well the Anandtech list doesnt include them.
Are you trying to see how well this PC compares to a similar price laptop/atom based pc?
I thought you meant the E6000/E7000 desktop (core duo) chips?
Oops E6600 n 7000 for desktop
http://www.overclockers.co.uk/showproduct.php?prodid=CP-388-IN&groupid=701&catid=6&subcat=567
Thanks
Is there other case options
Can that DVD writer be used for writing OS / CDs
Sorry I ment will it read CDs so I can install os.
The LG Super-Multi GH22NS70 internal DVD Rewriter features a 22x DVD±R write speed and a 48x write speed for CD-R. Designed for storage needs that demand consistency, the GH22NS70 reads and writes in CD, DVD±R, DVD±RW, and DVD RAM formats giving you the option to choose the media best suited for each task.
Thanks
What do I need to look for when choosing a case so that my components fit in
The ram will just run at 1333mhz, the 1600 mhz stuff is the same price so makes sense for the future.
A 7300gs it probably worse than the built in core of the cpu.
