20 Sep 2011 at 16:25 #1 rustynuts rustynuts Associate Joined 3 Sep 2011 Posts 277 Hey guys need just a quick conformation about the correct mounting of the rad. Is it ok to have it mounted like this or do i have to have it on its side (If that makes sence.. I ask because its the only way i can have it mounted due to limited space in case. Currently ingame my temps are 29c Thanks
20 Sep 2011 at 16:31 #2 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare I personally would have the RAD the other way up, so bubbles are trapped at the top cap and not entering the tubes.
20 Sep 2011 at 16:35 #3 rustynuts rustynuts Associate OP Joined 3 Sep 2011 Posts 277 It will fit the other way (Normal way) but i cant put the side of the case back on, its too wide for my case lol I might just have to leave the side off for now..
20 Sep 2011 at 16:38 #4 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare rustynuts said: It will fit the other way (Normal way) but i cant put the side of the case back on, its too wide for my case lol I might just have to leave the side off for now.. Click to expand... I mean rotate 180 degrees so the tubes are at the bottom, surely the width of the RAD doesnt change if its this way up?
20 Sep 2011 at 16:39 #5 rustynuts rustynuts Associate OP Joined 3 Sep 2011 Posts 277 Ah sorry i thought you meant 90 degrees.. Thanks
