** OcUK First to market with EK-Koolants @ 50% Discount! **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
We have secured an initial shipment of the brand new Watercooling fluids from EK. These coolants have been in development for some time and are manufactured by the worlds leading watercooling manufacturer.
To introduce the new line, we have established very limited quantities of the coolants at a special 50% discount.
The normal pricing of the coolants is £6 per bottle for the colours and £5.60 for the clear. We are currently selling the lines on pre-order for half price.
With stock due to arrive within a week, it is a fantastic opportunity to get your order in.
Stock wont last long before the pricing goes back to normal so be quick to secure your coolant now!
EK-EKoolants Clear @ £2.80 inc VAT
This proven premixed formula is a step ahead in EKWB product research and offer. Coolant is suitable for mixed copper, brass, steel, nickel and aluminum cooling loops, providing best value/performance ratio.
Ekoolant is the result of latest vigorous experiments on performance and influence, and contains best components which offer optimal protection from corrosion, yet allowing maximum cooling performance.
It's pureness, proper viscousness and low chemical content makes it an excellent and best suitable coolant any PC watercooling system.
The highly automated and advanced bottle filling equipment guarantees you exact volume according to the European Directive 76/211/EEC.
The printed numbers on top of the bottle allows each series to be tracked and show when the coolant was flled.
Characteristics:
- low electrical conductivity
- extra pure distilled/deonized water of electrical conductivity of 1µS/cm used for the coolant
- includes additives against algae and corrosion
- high quality concentrated pigments lead to intense, vivid and saturated colors
- not aggressive towards acrylic, acetal, rubber or other gasket materials
- ecologically friendly (85% degredable in 30 days)
- ROHS compliant
- 2 year shelf time
Techical data:
- color: CLEAR
- content: 1000 mL
Please note:
* As all other non-conductive liquids on the market, this coolant will become conductive and loose its characteristics if it comes in contact with other liquids or dust. It hence is advisable to keep your system free of dust and other particles.
* EKWB is not to be held responsible for any damages to hardware. User agrees utlizing at own risk.
* EKWB recommend proper flushing of all previously used watercooling components in order to minimize the risk of discolouring of EKoolant.
* Ekoolant already contains an anti-algae additives. Therefore we do not recommend adding of any extra anti-algae or anti-microbial agents. The addition of any other substances may result in a chemical reaction, which can cause dye breakdown and clogging which can harm your system.
Was £5.60 Inc. VAT
Only £2.80 inc VAT.
ORDER NOW
EK-EKoolants Blood Red @ £3.00 inc VAT
Characteristics:
- ROHS compliant
- 2 year shelf time
Techical data:
- color: Blood RED
- content: 1000 mL
Please note:
* As this coolant contains dye it cannot be guaranteed that it will not stain e.g. clothing or other materials when in contact. Please also note that dye fades with time and the intensity of the colour may decrease. That is why EKWB recommends storing this coolant away from direct sunlight.
Was £6.00 Inc. VAT
Only £3.00 inc VAT.
ORDER NOW
EK-EKoolants UV Green @ £3.00 inc VAT
Characteristics:
- ROHS compliant
- 2 year shelf time
Techical data:
- color: Lime Green, UV reactive
- content: 1000 mL
Please note:
Was £6.00 Inc. VAT
Only £3.00 inc VAT.
ORDER NOW
EK-EKoolants UV Blue @ £3.00 inc VAT
Characteristics:
- ROHS compliant
- 2 year shelf time
Techical data:
- color: Blue, UV reactive
- content: 1000 mL
Please note:
Was £6.00 Inc. VAT
Only £3.00 inc VAT.
ORDER NOW
Oh go on then. :p 3 litres of the blue stuff and a Bitspower crystal SLI link set ordered.
Edit/ Just realised that pic of the Bitspower Multi Link adaptor isn't the mini version as stated in the text, its the larger adaptor model no: BP-MBWP-C47 - unless I'm mistaken.
Which is it? I'm after the larger version.
let me check...
yes, it is the BP-MBWP-C47 as you stated.
the picture is accurate but the listing title is wrong from our supplier [thats the problem with watercooling, everything is direct of from the continent which means the language barrier is there]
have amended the listing now.
sorry about the confusion
let me check...
Oh fudge! I've just phoned the shop and they stated the title is correct and the picture was incorrect :confused:- so I cancelled my order. Never mind.
Edit/ As you're sure its the BP-MBWP-C47 I've reordered. Cheers for checking.
I have added the stock code to the item now.
it is definitely the one you quoted. exactly how the picture looks.
the blue one has a pic of it under uv light in the product description :)
the product is brand new and i am assuming the we will be one of the first UK companies to get our order so it is unlikely that any end users will have pics of it in a system yet.
the shipment should land this week
Was looking at it on my phone and it wouldn't let me see pictures other than the first one, think i'll grab some blue :)
Thought you where only going to be stocking only Mayhems Coolants RJK, Cracking price on the EK stuff though. Would have ordered a couple of litres if I wasnt so skint at the moment.
