Pic: Your desk...RIGHT NOW
Settings > Location services. It doesn't save where you live, it saves the GPS data of where the image was taken.
Oh yea i solved that bit, i was just curios as to how to view the GPS data on say the uploaded pictures with the GPS tag already assigned to it.
If you use FireFox, get this extension: FxIF. You can just right click the image in your browser and hit "FxIF Data".
If you're on something else, you can save the image, then right click the file and go to properties and get the GPS coordinates. You can also remove GPS data from here.
New desk :D
Danke, ordered :D
Castiel doesn't the amp get hot when in use and your monitor stand block the heat from the top vents? My NAD amp gets pretty hot and if I remember back from the 340R CA amp I had in the past, that too got pretty warm.
I'd recommend an Ergotron arm and then it can nicely "hover" above the amp allowing the vents to breathe!
Anyway, from the setup thread:
What amp is that? I just got a NAD 3020i from eBay which should be arriving soon.
Danke, ordered :D
Nice amp by the looks of it even if it's from the early 80s!!!
Mine is the C325 BEE, it kicks out 50w per channel but as you probably already know, these amps kick out better sound than high street stereos/amps that have more wattage. i can't use the volume above 9 o-clock without it being unbearably loud.
You will enjoy the 3020, NAD sound is quite a unique sound (I've had quite a few stereo/multichannel amps over the years) :)
I've gone through about 10 pages, hoping someone would name that mousepad/deskpad. What is it? I want one. I've never seen that orange logo before :D
what this guy says:
Is that a pair of hd25's I see? :D
correctomundo!
Interesting maroon mushroom-headed type thing on your printer :p.
its a lamp, but it doesnt have a bulb in it at the moment :confused:
