30 Sep 2011 at 22:29 #1 Daphatboy Daphatboy Associate Joined 21 Mar 2011 Posts 102 Hey guys, I was just wondering what you think about my cpu temps, as I want to make sure Im not running too hot or anything. Idle: 33°C Load: 65°C (Using Prime95) What do you think? Any help is welcome (Find my specs in my sig)
30 Sep 2011 at 22:55 #2 Surveyor Surveyor Caporegime Joined 5 Sep 2010 Posts 25,572 Isn't the maximum temperature for these processors 62°C? It would look a tad too warm.
30 Sep 2011 at 23:01 #3 Daphatboy Daphatboy Associate OP Joined 21 Mar 2011 Posts 102 What do you recommend me doing? I recently re-applied my thermal paste as I thought there was too much on it before.
30 Sep 2011 at 23:07 #4 Surveyor Surveyor Caporegime Joined 5 Sep 2010 Posts 25,572 Assuming that your cooler is fitted correctly then: a) Reduce the overclock b) Try and keep the overclock but reduce the voltage c) Buy a better cooler d) Invest in some better cooling for your case if it doesn't have good air flow e) Nothing - If it's 65°C running a 100% CPU use stress test then in real life usage you probably won't get to that temperature
30 Sep 2011 at 23:15 #5 Daphatboy Daphatboy Associate OP Joined 21 Mar 2011 Posts 102 Thanks for the advice What cpu fans do you suggest? I thought my fan was good Last edited: 1 Oct 2011
