How to force motion blur
I actually like the default fov, i will change it when i can, but it's bareable for now.
I get headaches occasionally when gaming for too long, Though strangely enough having a nicely packed joint tends to make them go away (at least for an hour or 2).
Not suggesting you try this but it certainly wouldn't harm you if you did.
If BF3 is the same as BFBC2 then it uses vertical fov scaling. A vertical fov of 75 would give you a horizontal fov of around 100, about right imo.
This is assuming the numbers are taken from a config file somewhere, I don't have BF3 myself.
Why do games include motion blur:
[Damien];20180002 said:
Usually because they can hide crappy performance/poor gfx behind the blur.
That was true in the beginning. Now they have forgotten that, and have developed more "advanced" methods of producing motion blur that, ironically, are more demanding of performance. Disabling it often improves performance now, I find.
