Man of Honour
- 16 May 2005
- Manchester
Couple of guides/fixes:
Config File Location
~\Steam\steamapps\common\rage\base\default.cfg
Enabling Console
In Steam launch options add +set com_allowconsole 1
Change FoV
Add the following line to the default.cfg file:
set g_fov 15
The above will add the number to 80 to produce the final fov. 80 + 15 = 95 fov.
Disable Mouse Accel
set m_smooth 0
Texture Caching Issues
Cba summarising it
http://forums.steampowered.com/forums/showthread.php?p=25497361#post25497361
Nvidia Card Issues
Disabling texture streaming in the graphics options can help if you're having artifacts and/or broken textures.
ATI Card Issues
Some are reporting that the 11.8 cats have the least issues with the game. Could be worth using until we get some new drivers.
Enabling Console
Change FoV
set g_fov 15
Disable Mouse Accel
set m_smooth 0
Cba summarising it
Nvidia Card Issues
ATI Card Issues
