Your box is broken. Get over it.
Agreed.
I'm on #3 in 4 years. Luckily #2 failed with 2 weeks warranty left and I got a 360 S as a replacement.
It's the same as Forza 3 - if you trigger the uncertification in the last sector it carries across to the next lap. It stops people cutting corners on the previous lap to gain an advantage on the certified lap. If you uncertify in the last sector just rewind and don't mess up again.
It might sound petty but if T10 leave the smallest chink open some **** will cheat their way up a leaderboard with it.
Stupid or not, rules is rules.
When the last corner is 180 degrees, the final sector need only be 100 yards before the corner, not another 2 corners before that. It's bad design and 5 minutes of testing it would have found this out.
It is stupid on that track though. You can mess up 2 corners before the line where there is no possible way you can gain any advantage, and it still penalises you.
Its not stupid, you're not good enough. try harder.
lol from what ive read ibert is very good.
ibert you're using a wheel right? if so which one please?
Whatever. I'm not getting involved in one of your irrational flame contests.
It was the same on F3, apart from Silverstone (go figure). If you don't like it go complain to T10 on FM.net, twitter or Facebook then vote with your wallet.
How on earth have the rivals leaders got 1.39 times!?
I'm giving it everything I've got and best I can do is 1.49![]()
Just using a pad at the mo muggs, but I have a MS wheel.
I think I'll be getting a Fanatec for this game though. It will be worth it.
