My system specs are as follows.
Core i7 920 @stock
Gigabyte-EX58-DS4 S1366 X58 ATX
Corsair XMS3 3GB DDR3 Memory 1600MHz 3 x 240-pin DIMMs 9-9-9-24
Dark Power Pro PSU 1000w
Western Digital WD 500GB CAVIAR BLUE
Asus Voltage tweak 5870 Stock
Xfi Gamer sound card
Windows 7 64bit
So in computer properties it states 3bg(2gb Useable) so I check online for fixes. I see the fix where you go into msconfig and uncheck or check maximum memory that still did not work.
I have checked for memory remap in BIOS and cannot find anything that resembles that at all.
I then went into Resoure monitor and noticed that is says 1026mb is Hardware reserved.
I have updated my BIOS and all other drivers for all my components. I have not overclocked anything in the system.
I would really appreciate any help as this is drving me nutssssssssssssss.
Core i7 920 @stock
Windows 7 64bit
