Lovely window - I was just actually in the process of drawing up something almost identical for my case. Was wondering what case edging you used, and did you manage to get a solid join?
thanks joxang, i used some stuff called "Blowhole Trim 1 Metre", google it, i got it from the place that Kan't spell there name properly. if you look closely at the picture of the window you can see the join at the bottom about half way across. as for affixing the perspex i need to double up on the tape to make it level with the trim. hope that helps
Looks really nice, and good job on the cable management. Think it would look a bit better if you pulled the pci-express cables a bit tighter though so its more bunched up
