- 19 Oct 2002
- Shakespeare’s County
The advancement in solar technology could mean charging stations can store power during the day at a much higher rate than previous solar technologies. Aren't current solar panels something like 75% efficient? And then there's that kid's innovation on panel array design (like a tree) which increases electricity generation by quite a bit.
Try 13% for one of the mainstream units that isnt an expensive galleium arsenide panel material. (20%+)
There is nothing limiting with the rate of solar charging, just need lots of area.
A pond of water with a turbine and lift pump is a simple way. Pump water up in the day using sun power then let it down at night whilst you generate electricity.
