what do you think to the gpu set up's with the case?
check the revisesd spec the corsair ram is one of the shortest you can get
also at a high res like 2560x1440 you'll soon need all the ram you can get at 1080 yer i agree no need but above you do
the ram is certainly better than in the old spec, but i really wouldnt recommend going with a 3rd 570, especially not that one because it is massively overpriced because of its unneccessary extra memory. you get diminishing returns when adding a 3rd graphics card too
if you really want a triple graphcs card setup then you will also need a motherboard that can do triple SLI at non bottlenecking speeds like the asrock Z68 extreme7
*edit*
i know theres a site that stulid uses a lot which does comparisons between a load of different resolutions with different cards. that would really help right now but i cant remember the damn thing
)I have not read through the hole thread so hope i am not repeating!
I would personaly get 2 smaller ssd, maybe the 60gb agility 3's and run them in raid. ssd speed for me has the most visable performance increase in day to day use. I would install the os on them along with all your other programs.
Put steem on your other drives! which is definatly possible as it is what i have done.
just my 2cent.
I have changed the case to the Raven 3. Even though I really do not like the design of the case (HAF X is much more my style) I do really like the way everything mounts inside the Raven, and the fans drawing air from the bottom of the case seems really good.
if you prefer the looks of the HAFX then go for that. i'm of the opinion that if you're spending over £100 on a case you should love the looks of it more than anything else
rest of the build looks fine. as you said you dont need the i7 2600k but theres no harm in getting it (except for your wallet)
Upgraded the cpu to the 1000w as Mr.May suggested just to have the extra power there if I want to put more in later.
Kept the mobo, ram, graphics cards and cpu cooler you guys suggested.
What do you think now?
