PSU problem
7 Jul 2010
Installed my new graphics card and PSU today. MSI 570 & OCZ Z 850w.
Everything is fine untill the PSU is put under heavy load. As soon as you get past menus and into a game it starts making a really loud screeching/grinding noise.
Sounds like this
I'm guessing it's a fauly unit and it's got to go back. Thoughts?
Does the PSU make the noise with your system running prime?
Does the noise the change when you try different games, as my GPU sounds similar to this when folding.
Just run prime and there was no noise.
I'm guessing it GPU related then? The sound is definatley from the PSU though.
Just noticed that when scrolling up and down a web page it makes a slight noise too.
Coil whine caused by electrical resonance and vibration between the gpu and the PSU. I'd send the PSU back.
Hey, I've got this problem as well with my ZX 1250w I received yesterday, so I'm assuming its a commonly occurs with the OCZ ZX series. Mine's driving me mad as I'm really sensitive to noise so it's really penetrating when I'm gaming with headphones on as well!
Did you send it back in the end?
You using a Nvidia card also?
I've got the same problem, have sent a webnote to Overclockers, but after reading around it seems to be a common issue with this PSU, I'm hoping for a replacement as well but would not like it if the replacement PSU has the same problem :( and afaik I think it's the product :(
this is not good news, I was about to get one my self :S although I am running ATI at the minute but wish to move back to Nvidia.
I will watch this thread for updates :(
