Clip on LED PC light
17 Aug 2009
Finchley, London
Just a quick question. I've been using a clip on led light to do stuff inside the PC and it's really good, very bright. But the clip broke so I need a replacement. I can't find the same one again, this one:
so was wondering if any of those LED clip on booklights that come up on the bay when typing in 'clip on led light' will be as bright?
replacing a torch because the clip broke? MacGyver up a fix!
i need to be able to unclip and move it to different parts of the chassis easily. Dong a DIY job like fixing it with ties is not really sufficient tbh, unless you have a different idea? :confused:
How about a mini-bulldog clip? I know it's not ideal, but if you have one around it could be worth a go and will save you some time/money in the process :)
I suppose that could work, yea. Not sure I have one around but I might try that.
Had considered one of those. Not sure if the light would shine as bright unless I had my head very close, or maybe it's better than I thought? Have you tried one?
The one I use is a cheap 3xAAA thing that cost ~£10. Combined with good surrounding light or a desk lamp, it's enough to eliminate any shadows and light up dark spots.
