** MAYHEMS AURORA - Pearlescent Watercooling Fluids **
rjk
rjk
Caporegime
8 Aug 2007
OcUK Is Proud to announce "Mayhems Aurora"
One of the most innovative products in watercooling today.
Check these videos out to see this amazing product in action.
Pre Orders being taken now, we are aiming to have stock on launch day which may be sooner than stated on the item descriptions.
With mlwood37 on our forums providing vendor feedback and development news, Mayhems is fast becoming a force to be reckoned with.
As new colours become available we will be listing them, also we will be working closely with Mayhems to bring you the newest developments from their lab.
Mayhems Aurora - Supernova Clear @ £14.99 inc VAT
Silver Pearl, Clear Coolant
Mayhem's 'Aurora' range of liquids are perfect for a myriad of differing computer enthusiasts. The liquid reflects light back in a plethora of swirls and differs greatly from anything currently available. A coolant that is not only striking to view inside a computer system, but it is a fluid that will entice the consumer with it's never ending patterns of light that cascade throughout.
The aforementioned Aurora' range is based on our proprietary blend of refined vegetable extracts, of which are fully biodegradable and have a very low order of oral toxicity. The bottle comes with a Child Safety Cap as well as a spout to enable the consumer can fill all manner of systems easily. This range of coolants is recommended for use in systems where an ‘environmentally friendly’ product is preferred. It also contains non-toxic (GRAS) multi-metal inhibitors, formulated to protect the water cooling equipment and associated systems against corrosion, scale and biological fouling. This prolongs equipment life and thermal efficiency.
Only £14.99 inc VAT.
ORDER NOW
Mayhems Aurora - Nebula Blue Coolant @ £14.99 inc VAT
Silver Pearl, Blue Coolant
Mayhem's 'Aurora'' range of liquids are perfect for a myriad of differing computer enthusiasts. The liquid reflects light back in a plethora of swirls and differs greatly from anything currently available. A coolant that is not only striking to view inside a computer system, but it is a fluid that will entice the consumer with it's never ending patterns of light that cascade throughout.
ORDER NOW
Mayhems Aurora -Tharsis Red Coolant @ £14.99 inc VAT
Silver Pearl, Red Coolant
ORDER NOW
Mayhems Aurora - Extinction Green Coolant @ £14.99 inc VAT
Silver Pearl, Green Coolant
ORDER NOW
Mayhems Aurora - Gemini Pink Coolant @ £14.99 inc VAT
Silver Pearl, Pink Coolant
ORDER NOW
Mayhems Aurora - Galaxy Purple Coolant @ £14.99 inc VAT
Silver Pearl, Purple Coolant
ORDER NOW
That green looks rather dark. Is it really that dark ?
Edit: never mind I found a vid on youtube showing it. Looks insane !
oh also question for Mlwood, will these work with the Koolance RP-402X2 Dual 5.25" Reservoir for 1 or 2 Laing DDC Pumps Rev.1.2 per chance. I noticed it has been said that these fluids most likely will not work with res/pump combos. Thought it was worth asking tho :)
Im sorry i cannot answer that question as we haven't tested it. The only ones we tested were the XSPC ones and found that they did not work because of the way they work.
We have a wiki Here -> http://mayhems-aurora.wikispaces.com/
How ever Coolermister did some testing for us and With Large Bay resivours were 1 Pump D5 is used and it takes up 2 spaces on a 5 1/2" bay the liquid did not flow as well as expected and i would predict you will have problems with it.
How ever with 2 x D5s to 1 bay res it did work.
This vid shows 2 x D5 in the top res and 1 x D5 in the lower res. You can see from the vid that there is not enough flow in the bottom res and eventually the pearl will drop out.
http://www.coolercases.co.uk/mayhem.wmv#
For 100% success with this fluid i suggest a Tube res.
Sorry. don't understand the only one two you can either keep as or change the colour to is the gold or silver. The gold we don't have pictures for just yet and are working on it. the green and blue are both pre-mixed ready to go.
Oh :(
Do you have any pics of the green under UV? Looks a bit too dark :(
Also, is it okay with the EK bay spin res !
We are not doing UV in Aurora or Pastel (all though some of the Aurora is UV reactive). Aurora works best with dark liquids but keep an eye out for future developments from us as we are still working on more solutions to make any pc stand out from the crowed.
If you after some thing different that will work on you system with no complexity then take a look at the pastel range. If your after UV aspects of a liquid then we have the X1 range that caters for that section of the market.
As for the Ek spin bay res i would not know if it works or not. We have a guide the bottom of our wiki of what we think works best and have given you guidelines on what we have tested. We cannot test every peace of equipment out there and its imposable for us to predict what will work and what will not work.
Aurora is a specialised liquid that has been developed more over for looks that any thing else and we feel overall that we have done our best to give you accurate information and tests to show how it works and what works best with it.
Does this work with the d5 pump at all? Presumably it will work with the tube-pump top reservoirs as there's one on the list.
