Man of Honour
- 21 Nov 2004
Will it be worth upgrading to this?
@theheyes: theres something like Exposé in Vista and 7 called Flip, just press the windows key + Tab. MS could simply have that implemented for Metro, but i think it would be better with it changed slightly so each app is stacked even more on top of each other like cards, not spread out as much, then that way you'd get more open apps on screen at once which helps for smaller screens.
If you're paying full price, have zero interest in Metro and hate the Start screen then I don't think you'd be at any particular disadvantage if you stuck with Win7 for a few years.
Bluntwrapped
Wish Microsoft would hurry up and catch up with Mac OS. IMO Mac OS is still years ahead of Microsoft.. functionally and aesthetically
Metro and the Start Screen are very small things overall. I wouldn't even mention them to someone asking whether they should upgrade (unless they're using a tablet).
Far more important things are the improved security, better performance, faster boot, less memory usage, Xbox Live, ARM support, better multi-monitor support, infinite backwards compatibility (Hyper-V)...
The below shot shows it with 160 logical processors. Apart from showing the percentage of CPU load for each core, each block gets darker blue the more loaded that core is.
Win 8 also now supports up to 640 cores(!!!), Win 7 supported up to 256, and i think Vista supported up to 64.
*snip*
And I can't agree that Metro and the Start screen are very small changes
That looks very nice, but I want that many cores!![]()
quick question, tempted to have a play with this, but i like my gaming,
anyone know how this version is with games? i assume all my win7 drivers etc will work fine for gpu etc?
Check out the Memory and Disk stats too... 1TB RAM and near 1GB/s disk performance...
Fair enough the disks, but 1TB ram! Holy ****!
