If you're talking about having the bars torqued up and things done properly, then I would think having the headset pressed in and the pedals torqued up would come under that as well?
On reflection, I should have added a few quid onto that estimate!
Why not get a decent custom steel frame made, then you'll never have to buy another frame again.Tempted to update my frame and groupset, I've been on my current frame and SRAM Force since 2007.
It's replacement frame and new Force groupset would cost just under £1000...
Just £20?! I was expecting more in the £100 range. This is certainly something i'll consider as i'm getting a boardman, just waiting for my bloomin employer to sort out cycle2work.
What Boardman are you getting?
Make sure you let me know if you do go down the 'buying it boxed route' and how it turns out, or how Halfords effort is if they put it together.
I'm not sure if the C2W thing is worth doing anymore with the change to the policy last year. I'll just use an online discount code saving 10% and then pay it off over 10 months on a 0% credit card.
Wrong. The correct number of bikes to own is N + 1 where N = number currently owned.[DOD]Asprilla;20343993 said:Theoretically, as of next week I will have all the bikes I need to cover all my requirements.
The amount I've spent on bikes would have been a reasonable house deposit[DOD]Asprilla;20343993 said:There is a difference between 'have too' and 'want to'.
Theoretically, as of next week I will have all the bikes I need to cover all my requirements. Doesn't mean I'm not going to buy a new one next year.
Platypus buys a new one every year.
Same advantage of bib shorts over normal shorts I guess, the bib aspect helps them stay in place. Leg warmers are easier to take off should you overheat.What are the benefits of long legged bibs over leg warmers and visa versa? Within a minute of cycling yesterday my left leg warmer slipped down but I think that's because I had the bottom tucked under my heal so my foot was pulling it down as it was fine after left.
I'll be getting the Team CX. I think it is still worth doing as they deduct the value before you pay tax on your wages, this can still result in a saving that outstrips most online discounts. When speaking to Halfords they claimed it was still possible to save up to 30% depending on how much you're paid.
For me it's just the convenience of paying it off over 12 months, any savings are a bonus.
Just spoke to a Halfords employee. Apparently they will supply a bike in the box, you just have to ask at point of purchase. They do not offer any discount as the build is a 'complimentary service' as opposed to being part of the cost of purchase.
My local bike builder has agreed to build the bike if supplied in the box for a flat fee of £60 which i feel is acceptable seeing as its them or Halfords.
[DOD]Asprilla;20345748 said:The race will be fine for London but a lot of folks like a CX for when it snows. However, it depends where you are commuting in London, roads are always cleared in London, it's really just those of us who commute to London from further out that have to worry.
