Just done the abandoned distillery quest, i really enjoy the shooting parts, i think they are excellent, it just makes me a bit frustrated that although the game is good, with a little more care it could be something very special indeed! I think that is the main thing i will remember from the game, that it had so much potential but just fell slightly short imo.
I actually think a dlc which just adds some random quests would be a decent idea for this game, something like adding some quests to the jobs boards or something you come across whilst exploring.
I was bummed with the laser attachment for the authority mg, would be nice to actually see the laser dot appear on enemies, instead it just disappears a few inches after the end of the barrel![]()
Does anybody else get horrific screen tearing with this game? I've tried playing around with Vsync but it just defaults itself back to 'off' resulting in the screen tear coming back. I know that's supposed to be a sign of poor performance but my rig doesn't appear to break a sweat at any point. Is there any way to force Vsync to stay on?
Yes, Nvidia (I assume) Control Panel. If you manualy add the Rage.exe to the application settings you will find it is set to Force V-synch Off; change it to application controlled and then the in-game settings will work.
I am near the end now so it doesn't matter a great deal, but can you set it so that you can use a controller for the racing/driving and not for anything else? I mean could i run over to the vehicle with kb/m and then junp in and instantly switch to controller?
Yep, this is exactly what I did and it works very well. Just enable controller in the options and that's it (in doing so it doesn't disable keyboard or mouse).
