 - 23 Apr 2009
 - Cheshire
what if i switch back to the other graphics card http://www.overclockers.co.uk/showproduct.php?prodid=GX-141-GW would that be ok ? because i really want that monitor![]()
Its got the same issue - it only has DVI and HDMI outputs - no displayport. So you wouldn't be getting the best out of the monitor, since you would be limited to the lower bandwidth HDMI connection. This thread has more info.
If you really want to go for that monitor then I would strongly suggest an AMD HD 6970 or HD 6950 2GB (perhaps two in crossfire).
 i added it now
